John Deere X 520 electrical question
Dwashebek
I have a 2006 John Deere X520 tractor. After sitting one week the battery went completely dead. Since the battery was original I decided to replace it. Before I connected the positive cable I performed a 12 volt draw test to see if there was an errant draw. There is a 7-8 volt draw withe the ignition key off. It jumps to 12.8 volts when I turn the ignition key on, which it should. When I unplug the console plug during the draw test it dropped to zero volts. Is this normal?
An amp/mil-amp read is more meaningful. I'm not familar with the X520 but even if it has things like radio,clock and such,amp draw shouldn't exceed about 50ma with key off.
