neighbors headache
hello all,, my next door tractor killer,,has a older sears garden tractor with a twin onan that has a fuel pump on the carb that no longer works,,he wants to put a electric fuel pump on it,, any idea what pressure pump is needed and where to get one. i never swapped one out but i figure we have to gut the old pump to make it work! any help would be as always a blessing and i thank you for it!! john
I got one from EBAY, 1-4 psi. about $13. Working good on my B&S with same carb. On mine there was a spare terminal on the key switch which I wired pump to so it comes on and goes off with switch.
B43/B48 was the most common used by Sears. You need a low pressure pump 1-5 PSI.You can still get repair kits for that pump. But they were not that good of a pump. Had a bad habit of housings breaking.
Onan tech since 1980.
