TractorLinks.com
Re: 1572 Cub Cadet
Married2Allis
04-21-2017 06:49:59
One thing you may notice -- an issue common with any of these year Cub Cadets is the wear that occurs on the hydro linkage. That will be evident when the hydro lever is in neutral, with the engine running ... the tractor will 'drift' forward or reverse. The symptoms are also that the tractor will seem to 'jerk' when moving the lever forward or backward and not speed-up or slow-down smoothly as was when new. They all do it eventually and the problem is not hard to fix. There is a spring that controls the smooth action of the linkage and that spring wears against the 1/4" steel plate where it sits. A new spring and restoring the plate edges will fix it. So if you see that happening, it is not a big problem.
