z830a jd mower
hoghollow
Looking at z830a jd zero turn mower. Anybody have experience with one of these it is supposed to have all the updates. Has 27 hp kawasaki engine good tires It has the 54 inch deck which seems a little small. I now have Dixon 6022ztr which is 20 years old and needs to be replaced
test ride it deere are one roughest ride out there yet. had two last year customers wanted rid of with less than 10 hours on them.
does yours have springs under seat a lot deeres seen come thru here are solid to frame. otherwise that great for you that you able to ride it.
How old is it?
How many hours??
How much $???
The 7-Iron deck is one of the best at processing damp/wet grass.
It?ll spread out the clippings without plugging up the deck or throwing clumps.
The 60? deck works a little better than the 54? because it has a larger exhaust area.
Ride can always be improved with correct tire inflation around 12 psi front & drives, and installing a simple seat-suspension system.
Also the urge to over-speed mowing conditions causes a rougher ride.
The early 800s had a jerky-hydro problem.
Test-drive it to see if the hydros are smooth.
Z800 series manual
I may be going there tomorrow and among other things use that mower. If I get there I'll try to remember to take pictures. Not sure if it has springs under the seat.
Well I didn't make it to the farm last Saturday but did today, grass was getting tall in places. I paid special attention to the ride and it wasn't bad.
