Wheel horse model L 106 wiring
Where can I find a wiring diagram for a wheel horse model L 106 that is a recoil start. I have one that was running and I fell off and ran into a chain link fence and died when it hit and that was a long ago. Had someone else work on it and I don't what they did or anything.
I don't know what year your L 106 is, but if it was ever digitized your local Toro dealer should be able to get you a copy. Its usually in the owner's manual for those mowers.
All I got, if you don't have electric start your only going to have a kill wire aren't you?
How many wires can it have, you don't have a battery ,starter or lights. The motor should run with out any wire to it, it just needs a wire from the mag to some kind of switch to stop it with a ground.
Have one wire coming from a toggle switch on the desk to a resistor by the points and a wire can Ming from the coil under the flywheel
