TractorLinks.com
New owner of john deere 300 garden tractor
Popo570
03-18-2017 21:10:14
Hi guys I just bought this 300 it runs and mows great. What was wondering how to put hitch on back for plow or tiller.can some one show or tell me how please
Bob
03-20-2017 13:15:05
 Re: New owner of john deere 300 garden tractor in reply to Popo570, 03-18-2017 21:10:14
A #33 tiller tiller attaches to the frame with it's own mount. If the tractor doesn't already have one, you'll need to obtain and install a rear PTO kit.
For a plow, you can use a sleeve hitch or a CAT 0 3-point hitch, depending on which way the plow you intend to use is set up.. There's sellers on the 'net with new aftermarket ones, as well as any Used ones that may be around.
Popo570
03-20-2017 13:27:00
 Re: New owner of john deere 300 garden tractor in reply to Bob, 03-20-2017 13:15:05
So Mr Bob does the sleeve hitch bolt to hitch in four bolt holes on each side?
Popo570
03-20-2017 13:24:04
So the slave hitch bolts to the frame in the four bolt holes that are there under seat on each side?
Bob
03-20-2017 21:12:56
 Re: New owner of john deere 300 garden tractor in reply to Popo570, 03-20-2017 13:24:04
Upper holes have spring-loaded pins that hold the sleeve hitch frame to the tractor frame.
For the lower holes, first you install a bolt on each side with a spacer on it, and the sleeve hitch has slots that slide over those as it's installed on the tractor, before the spring-loaded pins are aligned with their respective holes.
SuperHank
03-20-2017 12:21:24
Hate to rain on your parade but I never miss the chance to tell everyone how bad the 130 I bought is. It started falling apart in six months and since I bought it from Home Deposit there was no support. It was a problem. To anyone who asks...Do not buy John Deere lawn and garden products.
gab
03-21-2017 20:06:50
 Re: New owner of john deere 300 garden tractor in reply to SuperHank, 03-20-2017 12:21:24
Popo bought a good one, you bought department store junk.
Brendon-KS
03-21-2017 19:17:26
Most anyone who knows anything about vintage garden tractors would tell you that the Deere 300 was a stout, high-quality machine when it was made 40 years ago and would still be regarded as such today. The green and yellow paint is all it has in common with the consumer-grade, box store 130 lawn mower. To base your opinion of all Deere garden tractors ever made on your experience with the latter is quite narrow-minded.
SuperHank
03-23-2017 08:46:38
 Re: New owner of john deere 300 garden tractor in reply to Brendon-KS, 03-21-2017 19:17:26
If I worked at JD and sold lawnmower with my name on it I would be embarrassed that everyone commenting agrees that the 130 is junk. My only point and I am pleased that we agree.
steve_in_mo
03-25-2017 17:50:16
 Re: New owner of john deere 300 garden tractor in reply to SuperHank, 03-23-2017 08:46:38
The 130 is the current cheapened-down price-competitive John Deere riding mower product.
It's green and shiny and new. It has that new smell and everything!
It will mow a small level yard for quite a few years if you treat it properly.
If you expect the same performance from it as a you would a much heavier better built garden tractor, that's when you are going to be disappointed.
Roger in Iowa
03-21-2017 15:48:10
The 300 is NOT a 130. The 130 is a riding mower. The 300 is a Lawn and Garden TRACTOR.
I have a 1978 300. It is still being used. Wore out one deck. Never been overhauled. Hours, a bunch!
El Toro
03-20-2017 07:32:15
Your JD dealer should have a hitch. My old Wards tractor use's a sleeve hitch and I've made adapters so I can use a moldboard plow and a 2 wheel trailer. Hal
El Toro
03-22-2017 12:20:27
 Re: New owner of john deere 300 garden tractor in reply to El Toro, 03-20-2017 07:32:15
The plow came with a Viking 2 wheel garden tractor. It had a one cylinder engine. They also made a twin cylinder tractor. I think they were all built in MN. Hal
Popo570
03-20-2017 12:27:08
But I don't see what hitch bolts to on back of tractor the axle?
Roger in Iowa
03-21-2017 15:50:27
 Re: New owner of john deere 300 garden tractor in reply to Popo570, 03-20-2017 12:27:08
It doesn't bolt on. It is like a quick hitch. Slips over two bolts with spacers and two spring loaded pins go into holes in the vertical sides of frame.
El Toro
03-20-2017 07:38:29
That plow came with a 2 wheel garden tractor and I still use it with my Wards tractor. Hal
504
03-19-2017 16:08:43
Check out Weekendfreedomachines.com More information on JD lawn and garden than you every need to know. :)
