correct mower deck mounting
I know summer is now a long way off but I was wondering if anyone had a pics of the correct way to mount the 40 some in mower deck on a commercial 12 gravely it has the quick attach " spike" on the machine and the mower deck when mounted just using this is not right it moves too much it lifts when going ahead and drops so low it will cut grass for a putting green. So I would like to get it right in the spring. Thanks
Not 100% sure, but, one style the quik hitch pin was just used to line up the implement and you put the bolts in and the pivot was built into the implement. The other newer style the implement rode on the pin and just pivoted on that pin. If you have THAT type, maybe the pin or the attachment is worn?
that looks like mine and I think it is a commercial mower it is not kidney shaped and it has 3 blades the mower has 4 holes for bolts which is what I thought I would have to put bolts in to keep it mounted solid
I don't have that extra casting below the pin with the bolts in it like your pic shows. so do I need that to mount it right.
mine doesn't look like that mine mower has a cover over the pto and that is where the mower mounts to the power unit
will try to get pics when snow melts enough so I can get to mower
