TractorLinks.com
points for K series engines
jack345
03-13-2017 09:16:29
Is there a reason not to use aftermarket points ? My local NAPA said there would be no difference , Anyone have any experience between Kohler & good after market engine points?
MNGB
03-15-2017 15:07:22
 Re: points for K series engines in reply to jack345, 03-13-2017 09:16:29
They will not work on the Kohler K's many have battery ignition or they have Kohler's breakerless ignition, I have installed on 2 of my K series engines D Kirks points saver module and they work great.
he no longer makes the points saver but has his trandenserII these are a semi electronic system he uses the points as the trigger gets rid of the condenser.
http://www.kirkengines.com/
Mike M
03-15-2017 13:29:50
Does anyone make an electronic replacement for Kohlers ? Years ago I got some little modules to install on a Briggs and Tecumseh to eliminate the points but never used them either.
Butch(OH)
03-14-2017 06:07:29
Not sure what the Kohler points cost at a dealer but I have purchased several sets on Ebay for $15 delivered and aftermarket points are enough cheaper to entice me to buy them. That being said I have also installed the point sets that are supplied with the overhaul kits from Rotary Products and have not had any issues with them either.
jeffcat
03-13-2017 18:36:22
Big problem with "new" points, some have a coating on the surface of the points. You need to use carb cleaner and rub them with stiff cardboard. I don't like files or sand paper because it will damage the surface. Real old old old points had a very thin coating of platnum on them. Just what I have found.
MNGB
03-13-2017 11:32:36
I've used the aftermarket points with very good results.
GB in MN
