I apologize from the beginning since this is probably not the correct spot to post this.
The project is to out fit an electric cushman cart into a gas powered system. Its the two front seat style with a flat bed rear. The rear axle is currently a 9" ? electric drive, but I want to convert this to gas.
I thought about just adding a motor with a CVT, but then I wouldn't have reverse. Ideally need a system that drives by driveshaft and has a trans built in. Like an ATV system, but not the chain driven type. I could use a trans from a tractor, but it would have to be separate from the rear end. Most garden tractors being the rear end is integrated as the trans as well.
Any ideas or suggestions?
