Just figured I would inform anyone who is curious that I determined that my ignition module is what is the problem. After sitting for 4days in very frigid weather I did the ignition module test before starting and my voltage drops to 1vdc every one revolution. I proceeded to start the 318 and she fired right up. It ran for 8min exactly and she stopped. Did the ignition module test and no voltage drop at all constantly staying at the 12.3vdc battery voltage. In the process of removing the engine from 318, as of right now everything is disconnected besides the yoke/u joint from drive. Will pull out the engine and remove flywheel tomorrow morning. Also does anyone have any other valid suggestions that they recommend I do since I have the engine out?? This is my 1st time working on a 318 JD and am not experienced with these models. One other thing my battery light stays on even before I had this problem with it stalling does anyone have any ideas on what might be causing my light to stay on even though it's a new battery and it always starts...?? Is it the voltage regulator? I would really like to fix that problem as well. Any help would be appreciated! Thanks
