Hello looking for the ONAN GURU Billy
Schafer if he could possibly help me out?
This is my issue. My JD shuts down after
10mins of running and then it won't start
up until after about an hour of cooling
off. When is does shut off I have no spark
on either side of cylinders. I replaced the
condenser/capacitor and my coil no change.
The only thing left is my ignition module.
I did the ignition module check according
to the manual and other online forms and
what I get is when rotating the flywheel my
meter fluctuates from 12vdc to 0.9034vdc in
1 revolution. In the manual it states that
it should fluctuate between 12vdc to
anywhere between 1to1.5vdc. What my meter
is reading does that indicate that my
ignition module is the problem?
