White LT 110 yard boss 11hp
pirate8764
New User
I have a yard boss and I have to replace the electric clutch for the mower deck. I can't seem to find the part number for it. It just says Warner on it.... any suggestions
Sorry you haven't given us enough information to really help. But if it is a White Yard Boss, you may find some information here "http://www.shankslawn.com/p/White-Lawn-Tractor-Parts" ...
If it was built after the MTD buyout, there should be a tag under the seat with your model and serial number on it.
Another thing you can do is look up Xtreem clutches. They are on Ebay
and made in Florida. I have one one my 54 inch Husqvarna. What you
need to do is take all of the information on your tractor serial tag.
The REST of the information is on the clutch itself. Take the
electrical plug to the clutch out, then take the bolt out and drop the
clutch. Watch out it is kinda heavy. There will be another little
manufacturers tag with more infornation on the clutch. Also measure
the engine shaft size and length. Call Xtreem and they will cross
everything over for you. Very nice units and price. Comes the next
day! Comes with a new bolt and wire adapters if needed. Also follow
the,instructions to the TEEE!!! Stick a length of rope in the spark
plug hole when you hand torque the bolt.
