MMDEL
New to this forum. Can any one on here give me the part number for the matched set of
belts for the PTO on a Red Cub Lo-Boy. Model 154. THANK YOU VERY MUCH IN ADVANCE.
MMDEL
CIH # for a matched pair is 527382R91, about $65 at the dealership.
Aftermarket replacement is Gates 11M710, single belt, seems like people are using them in pairs and they are close enough so they work OK, about $26 at O'Reilly's, and $18 and up on the 'net.
One time working on a Badger silage blower and had to get a "matched" set of belts from NAPA in town. They were not even close. Make sure you take them out and stretch them between your right thumb and left thumb if possible. I had to go through every belt that size in the store till we came up with a set that was close enough. Still took a little tweeking of the motor mount and a couple of days throwing silage till they matched up. Down at work the guys made a "stretching" rig to match up belts for the big air handler systems. The really big ones take four belts and some have 20hp motors. Have fun with your CUB and matching stuff up.
