16 hp Onan engine parts
I got an Onan 16 hp engine that smokes and has blow by. I hate to send to scrap yard. Anyone need parts? I replaced the engine with a 20 hp on my Massey 1655.
YES, I desperately NEED a Carburetor for a 16 HP Onan....!!!
At Least a replacement float..mine sticks no matter how many times I check it..!
Hope you still have it..
If your carb has the composite float, then you need the brass float. Composite floats expand thanks to the alcohol in the new fuels and they will rub the sides of the float bowl.
Brian Hildreth can sell you the correct float. Contact him at [email protected]
I do still have all the engine if you need the carb. Email is open. I did talk to boomer but he was not interested due mostly to freight cost from Ms. To Mn.
OK Guy...!!!
Thanks and I need to know the particulars..!
I am in Central Ohio...
What do ya want for the carb ( assuming it was a good operating carb)..!
Ron.
GREAT to finally know why I repeatedly need to address the sticking problem..!!
I have worked this float down several times and it ends up sticking over and over..!!
Than ks for the information..I LIKE running this engine ( in my QT 16 Bo9lens) with dual exhausts..sounds like a Merlin engine and never works hard at all..!!
Just a note:
I am interested in the Carb for the 16HP Onan and am going to contact the person you suggested about getting a metal float ..
Thank you for your help, I have had problems with this one for several years..!!
