1872 cub cadet had leak
montidale
My neighbor brought a Cub Cadet 1872 down to look at. It has a hydraulic leak that is leaking out of the front seal and both top vents[caps]. It's leaking out of the seal like a sieve. I'm afraid just replacing the seal won't fix the problem.Has anyone seen this problem before?
montidale:
Both the front Input Shaft Seal and the Relief Valves can be replaced relatively easily. It is not uncommon to see leaks like this in tractors 30+ yrs old.
