Massey 1655 reporter question
I have a Massey 1655 and the engine is smoking and blowing oil out the muffler on the right side. I have found a 20 hp Onan and was
wondering if it will fit same as the 16 hp Onan or will there be a lot of modifications to make. Thanks for your help.
I suggest that you contact my friend Boomer at
[email protected]
If you provide him with the SPEC number off each of the engine tags, Boomer will tell you how identical they are in the key areas such as the crank output shaft, governed engine speed, location of the starter motor, size of alternator and so forth. If the new engine is close but not quite there, Boomer may be able to help you with the parts needed to make it right.
