kohler magnum fueltank
ihcase446
New User
anyone know is there A replacement part for the rubber grommet or A fix for it. the fuel valve goes though it.
its an 8 hp magnum hori. with plastic shroud/fuel tank one piece.
If its the grommet I am thinking of, about any good small engine repair place should have those in stock. Not necessarily a Kohler part number, but one that should work.
Check almost any dealer that handles garden tractors, atvs,etc. You can get one with a screen filter too. Like 15 bucks tops. My Husqvarna tank has a cub cadet fuel valve ib the tank. He he
The part is called a Fuel Tank Bushing..
Kohler Part # 25 313 01-S
You can find them all over the place for around $2.00.. I keep a few on hand for I have found that they fit a a lot of other fuel tanks besides Kohlers.
Here is another tick I use. Threaded Valve stems.. Run a piece of wire up through the tank and out of the filler neck. The remove the valve core and run the wire through the stem from the core end first and bend it. Gently work the valve stem down through the tank and out of the fuel outlet. Install the nut and tighten it.. Connect the fuel line with a small hose clamp. If you can work a 90* valve stem through the fuel outlet great. If not just use a 45* straight one..
<img src=https://c3.staticflickr.com/6/5770/30300081570_849dbafcbb_o.jpg"
