Engine Shaft reducer bushing?
IA Roy
Not sure what to call it, or where best place to get one. I have an electric PTO clutch that went bad on a B&S engine with a 1" shaft. I have a clutch from a K321 Kohler with a 1 1/4" bore. Both have 1/4" keyways. Is there a part that I can buy to reduce the bore, or increase the shaft to make these parts fit. The clutch mounting plate matches up to the Briggs engine. I found something similar in McMaster Carr that could be modified, but would prefer the correct part. Also posted on Tractor Talk. Thanks in advance, Roy
Goto ebay & search 1 1/4" shaft bushing,all kinds of 1 1/4" x 1" x 3/4"-6" bushings listed,depending on length needed.
Search 371495139421 on ebay & order length needed,in addition you get os key with bushing which you'll probably need.
MY MISTAKE,gave you wrong search number same was for 1 1/8"x1" bushing,search 331968416184 1 1/4"x1"x3" bushing,but you don't get os key with same,check sellers store to see if he sells same seperate.
Thanks, Joe just what I needed. I do not need a stepped key but a rectangular 1/4 x 3/8 as both shaft and bore are 1/4" keys. I thought I used every description to find one but failed.
