connor9988
- Location
- Central Iowa
My brother and I purchased a pair of Cub Cadets from a friends father. A 1720 and a 1450. Both currently are not running but were when they were put in the shed many many years ago evidently the 1720's hydro had something wrong with it and the 1450's front PTO clutch went out but it did get an engine rebuild. Anyways we went over and loaded them up on the trailer and 300 bucks later had them home. The 1450's tires all hold air however the 1720 has 3 tubeless flats.
The SN pictures are from the 1450. School me on the 1450 guys. We are wanting to get it running, add ag-bar rear tires and a sleeve hitch and put the Brinly plow on it. There is only one valve on this model (I'm not sure if more were optional.) Can you add a outlet to the 1450?
On the 1720 what are the common causes for hydro problems? Where do I check for the hydro oil level?
Finally, his father mentioned that before those two cubs he had another gear drive that had a rear PTO which he used to power small augers and elevators. I was under the impression that all cub PTOs ran the wrong direction for most PTO applications. Anyone know the scoop on that?
Thank you for all the help.
