There have been several threads on here about Briggs and Stratton "V"- Tech engines not running well. Went back and found Flying Belgian and 4435 for a couple. I have two machines with 21 and 22 hp engines on them. Had to rebuild the carb on one and found out all about the fuel jets and tiny "O" rings and on and on. Another thing is behind that black plastic block in front of the choke plate with the four little holes the fiber gasket swells up and the holes get choked off. Well a couple of days ago I was mowing with my big Husqvarna machine and all of a sudden it is running on one cylinder. Runs rough. The fastest check you can do is pop off the air filter top and remove the filter. Take a pump can with a little gas in it and with the motor running pump a squirt or two all of the way to one side of the air passage. If no change squirt the other side. All of a sudden the engine is now running on two cylinders for a second or two. You have carb problems. What is going on is these Nikki carbs are a closed loop balanced carb "have read this description several times", and when they goof up you now have 1/2 the gas to one cylinder and 1 1/2 going to the other cylinder. If you pull the plugs one is nice and clean and the other is all sooty. You can actually smell the one cylinder is running rich.
Here is where I found a BIG difference! I finally don't want to rebuild a carb again and went on flebay and bought a new carb. Take a look at item 331888382450 or any of the others listed. This is a THIRD revision carb and for about $115.oo it is a bargain! These are the ones built in Japan and it is the one you want.
Installed the new one on my machine and started her up .
MAGIC WAND TIME!!!!!!! Everything works like a magic pixie has blessed my engine. Beautiful smooth low idle, instant rev-up to speed and right back to idle. When going from lite grass to super heavy mowing the motor doesn't even change in sound never mind speed it just keeps going! EVERYTHING WORKS!!!!
Sounds like I am happy? Was it 4435 with the Zero turn? Go get one for your Zero turn. Fantastic carb! I would say it is like an engine with a crummy carb to an engine with electronic fuel injection! No kidding! Worth every penny. Total beauty.
