Wiring diagram for a Sears/Roper 3 pt hitch revisited
Gary from Muleshoe
Six years ago I posted on this site about wiring a Sears electric three point hitch. I have since lost the diagram a feller named "joe csuti" shared with me on here. I went to the archives and found the post but the diagram is no longer available. I have the switch I just need the diagram so I can wire it up on my recently acquired Sears SS16. Can anyone help me out with this. Thanks in advance.
I am no longer online so all the drawings/scans I had in my online storage site are gone.For the past 3-4 wks I've been doing work at my stepson's house & he's online,usually if I get a chance I check this forum,I have no way of posting a wiring diag of sw however if you have correct radio shack dpdt momentary center off sw I will try to walk you thru wiring of sw.
Looking at sw from back on a pc of paper draw the 6 terminals in 2 vert rows as they appear on rear of sw & label screw terminal drawing as follows:
left row:
top terminal-label #1 draw a short line to same & label +12v,also draw a line from this terminal to terminal #6 & label jumper wire.
center terminal-label #2.
bottom terminal-label #3.
right row:
top terminal-label #4 draw a short line to same & label -12v also draw a line from this terminal to terminal #3 & label jumper wire.
center terminal-label #5.
bottom terminal label #6.
Connect motor leads(2) to terminals 2 & 5 and you're done!!
Rotate sw 180 deg if needed to match sw handle direction to lift direction.
Good luck with same,when I'm at stepson's next wk I'll check forum to see if everything worked ok.
