steve terplak
I have a MF 10 that has not been running since I have been in possession of it.
When I turn the key, the starter cranks, motor turns over, does not fire or attempt to fire.
I have power at the ignition coil (or at least I assume since when I put the positive lead of a multimeter on the incoming black wire, while
engaging starter it reads as having power.
The spark plug, does not have spark and, when putting the positive lead from the multimeter in the plug boot...it does not appear that power
goes to the plug.
What is the process for determining what is not working correctly?
Thanks in advance
goes to the plug.
Thanks in advance
