** Got the 444 going ** pic
Dutchman
1st... I want to THANK everyone that help .... my son and I have been working on the Case 444 for over a year { off and on that is } ...got it painted and had a problem getting the engine running right . it would backfire after it ran some ....
I replace the points , condenser , the wire going from points to coil , plug , fuel pump , carb. and when having it running ... I accidently put my hand on the coil { it burned me } so I got my check heat gun and the top of the coil was over 230 .... so I replace the coil ...
I runs like it is suppose to ... had it over and hour ..and all's good ....{ boy what you find by accident } best thing there's new parts I don't have to replace ...
Again THANKS to ALL that help me with advice ............... mark
I didn't do all this to let it set in the barn .... it will be used ... just will be careful with it ...
.......... mark
Hi that is a nice / pretty Case 444, glad to hear is running as it should, yep sometimes it an accidental thing that finds the cure.
GB in MN
