Have a john deere x300, 42" deck. The person using it hit a stump while mowing. Now leaves about a 4" strip of uneven grass right in the middle.
First thought bent mandrel shaft, but after further checking, the deck is sprung where the mandrel bolts on. Has anyone had any luck
straightening them out where the mandrel bolts and if so, how did you do it. It is the mandrel on the chute side and the outside mounting holes
are lower than the inside holes.
