TV Iron
I have a Model 1257 Wheelhorse tractor that came with a snow blade (Model number 64112---serial number 349233). The seller said that it was a quick attach blade. Does anyone have a manual or information on how to attach the complete snowblade? I have the rear portion mounted to the axels, but it appears there should be other pieces to support the sub frame of the snow plow.
Theres a couple forums that keep alot of manuals available online... external_link dot com and gardentractortalk dot com
I dont like to put direct links up to other forums so just do a search and you'll probably find what you need
The only thing that holds blade to tractor is the 3/4" rod on end of blade A frame & slips into quick disconnect on rear axle & the lift rod from blade frame to rock shaft arm for lift handle/hyd lift on tractor.
Google wheelhorse 6-4112 & click on link to wheelhorseforum.com in listings,in manuals section of website you can view/download manual for blade.
You can also try toro website below & see if manual is avail as a free download.
https://lookup3.toro.com/request/request.cfm
