Hi everybody. I'm new to the forum. A week
ago my Deere 214 garden tractor stopped
running and it won't start now. I had just
filled up the gas tank, and I started the
engine to let it warm up before cutting
grass. It was running fine for about 2
minutes, but then it started idling rough
and eventually it died. Every attempt to
start it, after that, would lead to it
barely running and missing, for about 30
seconds, before dying again. I verified
that the spark plug was firing by grounding
it to the top of the engine and watching the
gap. I made sure the fuel cap vent was
unobstructed. I then removed the float bowl
and found it full of gas. So I thought a
carburetor rebuild might be worth a shot. I
got a carb kit from NAPA; part # 7-02024.
I soaked the carb in parts cleaner and
cleaned it thoroughly. I noticed that the
fuel inlet seat that came with the kit was
different than the one I was replacing. I
showed NAPA and the guy working assured me
that it was the proper kit for my carb and
that sometimes they make design improvements
to the original parts. The carb I have is a
Kohler #26. I reassembled the carb using the
new fuel inlet seat and valve, and set the
idle jet to 2.5 turns off bottom; main jet
to 3.25 turns off bottom. It cranked, but
wouldn't fire. I then set both jets to 1.5
turns off bottom and tried again. It will
fire once, but won't start. It's like it
coughs, but doesn't catch. Then after
trying 4 times, something happened to the
starter. The battery is fully charged, but
when you turn the key the starter relay
clicks once and nothing happens. The
starter is only one year old! Did it get
stuck? This tractor is infuriating me and I
have 2 acres to mow! Please help.
