deadeye123
A friend has a Scott's lawn tractor with a 17hp B&S engine. He had already put a new battery, switch, & starter on it. He brought it to me and I checked , cleaned and tightened all wires and connections. also replaced the solenoid. Thought I had it. It started 8-10 times in a row, then it would only click. Some days it will start every time then it will act up again by not starting, only a click at the solenoid. I believe he got a bad ignition switch when he replaced it. I will be going back to check it out next week. will jump a wire to the solenoid to eliminate the switch. any other suggestions out there?
