Cub cadet 109
tbish
Could anyone direct me where I could buy a PTO switch for the 109 I can't seem to find it on the web thank you
Tbish:
The reason you can't find one is, that there never ever was one.
The 109 rolled out of the Factory with a Mechanical PTO Clutch, engaged/disengaged by a Lever.
R Bedell is right.
Its not unheard of to find one re-powered with a later engine that used an electric clutch. I have a 149 like that. Has a Quiet Line engine in it.
Post a picture of the switch and maybe someone can identify it and tell you where to get one. A picture of the back side would be helpful as well. Lots of pto switches had safety interlock contacts built into them as well.
After doin some more investigation on the little tractor I see someone put a 312 engine on it
