All kinds of electricals
Erich64
New User
When my Pro master 200 just died while mowing, I discovered it was a 30 amp fuse. I replaced the fuse and the mower started but the PTO will not engage. Is this somehow connected to the fuse going out?
In certain cases the pto clutch could be the cause of the fuse blowing. A shorted winding in a pto clutch can draw too many amps and cause the fuse to blow. Resistance should be between 2.5 and 5 ohms.
Also a non working charging system can cause a fuse to blow., so could be 2 unrelated problems.
(quoted from post at 18:54:40 08/11/16) In certain cases the pto clutch could be the cause of the fuse blowing. A shorted winding in a pto clutch can draw too many amps and cause the fuse to blow. Resistance should be between 2.5 and 5 ohms.
Thanks for the tip. I'll check the wiring to the PTO clutch tomorrow.
(quoted from post at 18:57:34 08/11/16)
PTO clutch is at 2-3 ohms. Didn't Check the seat safety switch yet.
