Sonny in Mn
I was given an Ariens Zoom ZTR with a Kohler Command 21 model CV23S. The engine leaks oil from the top main seal. I removed the flywheel & the
horseshoes on the ignition modules are beat up from flywheel contact. I believe the top main bearing or crankcase housing is bad. Is this a
throwaway engine or is it worth repairing? Mower has 450 hours on the meter & I believe it was working. Thanks. Sonny
