Gravely just died.
Erich64
New User
I was mowing the other day and my Promaster 200 just died like I turned the switch off. 22 hp Kohler. I checked the battery. All is good. Checked the ignition switch, no power to it. Power to starter sylenoid. Is there something in between I should be checking?
Mag or battery ignition?? If battery ignition try a hot wire to the coil. If it run with a hot wire then your problem is from the coil back.
