Mower Deck for Cub Cadet 1320 Hydro needed
c huff
New User
I need a used deck for my 1320 Hydro. Current deck is falling apart. Anyone successfully welded one back together?
Yes, they can be welded.
I've had better success with plating the crack instead of just trying to weld over it. Also study the nature of the break, as in what caused it? Try to do some creative bracing to prevent it from happening again.
Getting down to bare metal is important too. Grind away old paint, rust, grass. The coarse grit flap discs work well, gives a polishing effect, makes seeing the end of the crack easier.
I'm not far from there. I think your 1320 takes a 38"deck. I have a 46" if you're interested. My 1730 is parked with a bad rear. Have no plans for the deck. I think you're 12.5 Kohler would handle it fine. The 1320/30, 1420/30, and 1720/30 all shared the same chassis so it should fit. Let me know. Otherwise, like Steve says it can be welded.
Thanks all for your kind help. New to me deck is in the back of the car. Will be mounting it up tomorrow...
