Cub cadet lift assembly
alderman
I have an older cub cadet 2050055u541797 which unless I'm mistaken is a 1000. I'm trying to find information for mounting a harvester
international tiller on it. I believe it's called an a-1?
Beside the tiller itself there is a gearbox that mounts on the rear of the tractor to run it and you need to have the optional creeper gear and if you dont have hydraulic lift you will need the lift assist spring kit.
