Anyone know what is missing on this dash?
T Man44
Please see attached picture, there is a hole in the upper left side of the dash and I'm not sure what used to be there. On the right side there is a cigarette lighter as well as the pull switch for the lights. If anyone knows please share, thanks.
Here is the photo.
Actually I found an image online, what's missing is an ampere guage. I'll have to try to locate one. The choke is part of the throttle, all the way up is choke.
I'm sorry to tell you this but those pictures are of two totally different machines. the red one I assume is yours, that hole isn't near big enough for a gauge of any sort.
They are the same machine, some previous owner painted mine red. The gauge face is likely bigger than what actually fits in the hole.
Looks to me like the steering column area protudes outward from the dash on the red one, while on the white one it is recessed.... that isnt the same dash panel, and Ive never seen an amp gauge made to fit that small hole. It was most likely a choke pull but someone has changed the engine and/or carb and a seperate pull was no longer needed.
Those are different dashes, one will not work for the other. And that is not for a guage of any kind.
The Dashes don't look the same and the gauge in picture is most likely an add on that somebody did because lawn and garden tractors like that don't come with that nice of a gauge from the manufacture.
