Allis Chalmers B207 jackshaft
The 1601091 shaft and bearing for the double sheave on the tractor is no longer available from Simplicity or AC. This is a water pump bearing. John Deere JD9355 bearing will work as a replacement. The bearing is identical. The shafts are about 1/8" shorter on each end but will not affect the really good overall fit.
