rod bolt torque
IH10020
specs call for 240in lb. which converts to 20 ft.lb on k301 kohler. don't have metric wrench can I just do 20lb with regular wrench & be safe. HAPPY 4TH!!!!! thanks for any replies.
So, you don't have a metric socket to fit the bolts? And you have a foot pound torque wrench?
If you have the right socket, yes you can use the foot pound wrench at 20 ft lbs.
For the price of a socket, I would rather have the peace of mind!
I don't understand the question. All Kohler k301s that I am aware of use standard size fastners. The only exception that I can think may be if you have a different rod than the original, with different fasteners.
If the spec. calls for 240 in.lb., then 20 ft.lb. should be fine with your torque wrench.
If it is a replacement rod, be sure to use the torque spec. that was in the package the rod came in, which may be different from the manual.
I wouldn't. Inch lbs is much more accurate, besides if it is a clicker wrench most ft lb versions don't even adjust down that low... and no torque wrench is as accurate in its lower most 20% of its RANGE than in the top 80% of its range (notice the rated range rarely starts at "0" which ever scale you might be using!!! With Kohlers tendency to blow shortly after a rebuild I would do it right, with an inch pound torque wrench... Im sure you gotta know someone that has one you could use for long enough to finish this rebuild.
(quoted from post at 17:06:48 07/04/16) I wouldn't. Inch lbs is much more accurate, besides if it is a clicker wrench most ft lb versions don't even adjust down that low... and no torque wrench is as accurate in its lower most 20% of its RANGE than in the top 80% of its range (notice the rated range rarely starts at "0" which ever scale you might be using!!! With Kohlers tendency to blow shortly after a rebuild I would do it right, with an inch pound torque wrench... Im sure you gotta know someone that has one you could use for long enough to finish this rebuild.
I have to disagree: Inch pound torque wrenches are not any more accurate than FT Lb ones if they are calibrated, all the Ft lb wrenches I have go as low as 20 FT LB and clicker types are just a accurate as a dial type if calibrated the only ones that are pretty much worthless are wandering arm / rod things.
Go ahead and torque your bolts per the specs with your wrench my Kohler manual says a higher torque but as posted if its and aftermarket rod it could be that number.
GB in MN
This might help in your quandry. It is from a Woods service manual (if wondering)
i thought that to, but rebuild warranty will not go for it so do it in inch lbs, but on your own probably would not. i have both types of torque wrenches anyway have for several years so no big deal.
http://www.small-engines.com/kohltorque.
i have both inch pounds and foot pounds and would use the spec given.it would be hard to argue that a calibrated wrench would be any better either size but as calibrated each is given a plus or minus value. so if each wrench was off by 3% how much difference is there? you do the math!
