drewmiller5007
New User
I just bought a beautiful Ford 100 that I finally have running good and the first time I take it out to test it and it throws the transaxle drive belt. I pulled the wheel and put the belt back on and it did the same thing. It works great if you are going in a straight line or straight up or down a hill but any uneven ground and it throws it. I took the pulley off and the part number is 218013 it is the singe pulley and it has a crack in it. The shaft does have a very small amount of play in it so that might have something to do with it as well?? Either way I will need a new pulley and maybe even a rebuild kit for that shaft??
Anybody know where I can get a pulley??
And what are your thoughts about what is causing this??
