Have a Carb. Question
Dutchman
I figure if anyone would know .... it will be on this forum // Question : if the carb. opening that goes to the engine is a 26m and it is suppose to be 30m ... WOULD that cause the engine { kohler 14hp engine } to idle and a little faster , but put it fast and it acts like it's under a load and does backfire once in a while ...
I'm trying to narrow done , whats wrong .... check valve clearance , points are right on ...
THANKS to any advice you share with me ....... mark
You will need to check for a good seal,it could easily cause a vacuum leak. That will make it run lean, fast idle, and backfire.
