old cub cadet
caterpillar guy
I need a clutch for an old cub cadet. Made before they started model numbers according to the dealer. They list it as the original cub cadet. 7 hp kohler engine.
Serial number forth coming in the morning, not my tractor. he thinks this is a 60-63 model. Sorry best I can do for tonight.
This is the traction drive clutch.
Ya there is no model # on them, so they have been nick named the Cub Cadet "Original", or just CC "O" for short, I had a '63 for awhile and found the guys at 'onlycubcadets' quite helpful.
Ive had several Cubs and still do actually, I have a little Red 382 hydro, a model 126 with a creeper gear, and a Loboy 154, all of which were built before MTD took over.
The serial number on the 'O' can be quite hard to see, its stamped into the right hand side of the clutch case, just behind the frame and just in front of the rear wheel, and usually quite faint, but if you can find it you can date the tractor, it will be either 4 or 5 digits.
