That little thingamajig....
Bret4207
On a carb with a choke cable, there is often a small fitting in the choke arm that has a screw to secure the cable and allow the choke to operate freely. I mean the solid part of the cable, not the outer covering. This piece goes in the choke arm that operates the shaft. I don't know what it's called, but they come up missing all the time. Anyone know where and what to look for?
GOOGLE "Throttle cable ferrule" or "Throttle cable set screw end".
<img src = "http://www.greenskyadventures.com/throttle_cable/wire-eye.JPG">
B0b I hope you done good. I read his question and thought it might be the same thing for his cable. Hope or two thoughts are correct.
(quoted from post at 12:24:12 05/18/16) GOOGLE "Throttle cable ferrule" or "Throttle cable set screw end".
&lt;img src = "http://www.greenskyadventures.com/throttle_cable/wire-eye.JPG"&gt;
That's the sucker! Thank you!
(quoted from post at 10:25:01 05/20/16) Google Solderless nipple and all will be revealed.
Thanks Ray, but "solderless nipple" appears to be a UK term for a US throttle cable screw end.
