Pitch
Just picked up a LT 111. Has bald front tires. Is there a secret to getting the wheels off? Took off the c clip and no joy. Is there something else to do or do I just need to hit the ale with the Dremel Tool? I don't feel a big ridge. 300 hours showing on the meter if that means anything.
Smack the back side of the rim with a block of wood and a hammer. My opinion of the 111's is they should all be in the scrap pile.
Stuck fronts is not a common issue, Im guessing you applied some penetrating fluid? A hammer isnt something I would recommend with or without the wood block you can easily damage the wheel or break steering components. Heating the center of the rim with a torch might do the trick but that will destroy the paint. If you have access to a bearing press you can pull the spindles and wheels together and try pressing them out.
