DMartin9N-2N
History: A few days ago, I emptied part of a 2-gallon gas can into the tank on my 212 lawn/garden tractor. Yesterday, I started it and it had a little black smoke in the exhaust for about two minutes, then quit running. My instinct was to try a little starting fluid, but when I opened the air filter, I got one hand filled with gasoline and grass cuttings! I feel sure the grass cuttings were blown in by the flywheel fan, and were between the metal filter housing and the element, so that part makes sense. But why was there about two or three ounces of gas standing in the bottom of the filter housing? This tractor has a fuel pump, I think because the gas tank is lower than the carburetor. Could I have overfilled the tank a few days ago and gravity-fed several ounces in to the air filter? (After cleaning things up a little, the tractor ran fine for over an hour's grass cutting until I shut it off.)
Dennis M in W. Tenn.
