kohler carb.
cheif
Is there a source for a carb for a kohler command 12,5 for 1320 cub cadet? The part # as listed in the parts manual is KH- 12 85301. I don't know if it is worth fixing this od mower but it is a challenge to make these old machines run like they are supposed to. I soaked the carb and put a kit in it but it still runs lean and is reluctant to start. Thanks.
If it's been sitting for a long time with gas in the carb. They get so plugged up you need a new one. Kohler dealer should be able to get one. It will be pricey. I asked about a Kohler carb last week. Kohler wanted $202.00
If this is on a John Deere machine. You have to go through Deere.
Thanks for the feed back.Itis running better I think soundguy has the answer. I hope the sea foam and a few hours will clean it out. I ground the valves and the carb seems physically in good shape. I mowed with it yesterday but it still seems to be running lean. I don't know the history on the machine but hope there is some life in the old girl yet!
