yard sprayer
Setting up sprayer for yard questions on application rate, sprayer is mounted on my Dixon ZTR. have tested with just water and use about twice the liquid that instructions say to use I am moving about as fast as I feel comfortable with. Do I just need to reduce nozzle size to put on less product? I am using 110-02 nozzle covering a 4 foot path
You could go to smaller nozzles or just mix the product half as strong. It's all about how much actual chemical is applied over a given area, not the total gallons of solution. You'll be filling the tank twice as often but for a smaller area this probably isn't a big problem. Might have a little less drift and fewer plugging problems than you'd get with smaller nozzles, too.
