10HP Kohler Parts Needed
John B.
I have a 10hp Kohler Engine. It's on an old Case Garden Tractor. I need a fuel pump and electric starter for it. Do any of you have parts that you would sell? I can get you the model numbers. Don't have them right now or I would post them with this message. The starter works but just needs brushes.
Call or text John
618 979-1972
Thanks for any help.
The fuel pump for the really old cast iron block "K" series engine that weighs like 100lbs.????? If you look on flebay I think this is the correct pump. Take yours out and look. 141954254642 If you have a starter generator from like 1967/68 and back then you are on your own. The newer geared modern starters there are two types. The older from 1968/69 has a little tiny field in it and has two brushes. Not a lot of turn over power. The slightly newer ones 1970 or so are smaller in diameter and have permanent magnets with four brushes. PLENTY of crank over power. Had to change the one on my Gravely and they are super. That is all of my advice. Get back to us.
The starter has permanent magnets and 4 brushes. It's not the generator/starter set up.
I don't know if you can get just the brushes. I pulled mine apart and it was fine. Just did a clean up on it. A GOOD generator starter shop might have them. On flebay they used to sell rebuild kits. They are a bit of a BEAR to get back in. Be very careful cause that magnet will pinch you like crazy. Look up the Kohler engine service book for the "K" series engines. Has a whole section on those starters and how to do. Do a search on this site, it should pop up.
