MARK ROBKE
I have cv750 30hp Kohler command engine in a zero turn mower.It seems to have plenty of power at high rpm,but it won't hardly idle,and idles rough.I replaced the spark plugs,and the left one was a little carbon fouled.If you slow the engine down from high rpm it sometimes does a small backfire,and tries to stall.The throttle does not do anything until about halfway thru it's travel.I understand this engine has hydraulic lifters,so I guess no adjustment,right? And the carb is a 2 barrel with a choke plate,and has some kind of solenoid on it,like a form of fuel injection.And I see no adjustments on the carb,except idle speed.One thing I am going to do next is a compression check,but if that is ok,and I think it will be,what next?On a normal carb I would adjust low speed mixture,but not sure about this one.Dirt in the carb passages,maybe?Any suggestions or help is appreciated.Thanks,Mark
