Still need help on M-F #12 hydro release
Savinsam
I've asked for help before & got it here as to the location of hydro release. However, no matter what position I set the lever at, and rock the tractor, it won't release. Lever has a slight bit of resistance. It seems to turn properly. Could something be broken in there? Again, thanks for any help.
Are you finding the rotary release valve on the trans front under the frame? Should have an offset length roll pin through it. If I recall with the long part turned up is freewheel position, and down is run position. Hydra lever can stay put.
Yes, I've found the proper lever. Doesn't matter where I set it, nothing changes. I've even moved it in small increments both ways. It's got me baffled. Thanks, Sam
