Late model cub cadet
Animal
The belts for the mower were slipping so I replaced the PTO and deck belts with gates belts, they act like they are slipping too. Do I have to use OEM belts on this machine?
It seems unlikely that [u:64f182effc]both[/u:64f182effc] the PTO belts and the deck belt would be slipping, especially if they are all new.
Try to determine which it is and then why they are slipping.
Recheck the deck belt routing and be sure the idler spring is hooked properly and the idler arm is moving freely.
Maybe you have another problem on that machine. Do all the pulleys and spindles on the mower deck drive spin freely without growling? I mean check them with the belts off.
Check for pulley wear and the correct belt fit.
