Two issues with this unit. Doesn't start using the choke which is over travel on the throttle. I mess with it all kinds of ways, but the only reliable way of starting it is pouring a little gas on the foam surrounding the air cleaner. I have not dug into it, but suspect there is a choke plate that is not closing.
Problem 2, when I get a little off of level, the left blade spindle pulley rubs on the bottom of the foot rest. The deck does not appear to be centered. If it were centered the pulley would probably be inboard enough to clear the footrest flange that turns down. Is this normal, or is it out of position.
Thanks in advance, if I get these thing fixed I will let you know. It may take some time though. Roy
