Ford YT16H Fluid Specifications
moddedstang
New User
Hello,
I recently inherited a very nice Ford YT16H (9800687) lawn tractor. I want to perform a maintenence overhaul on the machine and have some questions on fluid specifications.
I believe the hydrostatic transaxle is an eaton 850 if I am correct. I found out that the fluid and filter has never been changed. The owners manual calls to use a detergent SAE 20 oil. This seems to be very hard to find. Called a few new holland dealers and all gave me a different motor oil recommendations. I called Eaton and they told me all of their transaxle left the factory with hydraulic fluid.
What would you guys recommend using? Also, if I do change it, is there a chance of removing sediment that could possibly be holding it together like what can occur on some car auto trans that have never had fluid changes?
Thank you in advance for the help!
Jason
I would run a good quality Universal Tractor Transmission and Hydraulic Fluid (UTF) in it.
